talk about hijacking karlj's thread.....sheesh!
Haha I don't mind it's turned out to be quite an interesting read :grinning:
If I was to use the carbs as quad bodies what's the largest injectors I can use?
Will you be making another home brew tubby setup? Arghh, talk about hijacking karlj's thread.....sheesh!
Do you remember the cc for the ga15 ones I have frank
What are you planning karlj, mounting carb bodies onto stock inlet manifold runners and rigging up an airbox/filter setup with MAF to meter airflow?
If you have enough parts to go either way, why not do both? Bike carbs are generally pressurisable iirc so won't have any issues running boost
