carb,s are a bit of a backward step on an injected car imo
thanks for all the response im trying to way up power gains to cost cause a set of bike carbs is gonna set me back £200 but how much will throttle body set up set me back?
Arent TBs ECU controlled and Carbs are just antique design which should be thrown away??
Unless twin 40s sitting on an Escort Mexico!!!
car mechanic but cant get performance at trade prices only engine work doin a race engine fuelin etc an an lowered an ajustable sus got to get yet got bout 2500 limit
building it all myself
running a motorsport fuel pump with adjustable regulator.
-front camber bolt kit
-front lower and upper strut brace
-rear hd 22m antiroll bar
-weitec lowering kit by 35mm
-adjustable fuel regulator for carbs
-8.5mm performance plug leads
-piper ultimate cam kit
-ashley exhaust manifold
-custom made bike carbs
-paddle clutch kit
-complete engine work with new
ive already got a set on order due int he nxt couple of weeks .well made tho look top class
yeh, it makes mine sound like a 2 strokeThe noise coming from that engine is what you call beefy!
i might be being stupid here, but are those actual carbs or are they throttle bodies? arn't throttle bodies better?
Hi Nex, they are bike carbs but a lot of time and money has been spent it getting them correct with regards to set up these aren't your homemade set up. Yes throttle bodies are better but they cost four times as much, but the power gain we hope would be roughly the same. (Y)
Do you want a set for your cabriolet?
mate i would love a set, but its all money isn't it. i suppose the thing with carbs is the setting up, thats the expensive bit...
why do you need an ecu if they are all carbed up?
Just so you know with no AFM on the K11 ecu it has no load input and ignition will be way out from what it could be. (although connecting it to the TPS may help - if the carbs have one)
Something has to control the ignition.... 3D mappable ignition is the best thing since sliced bread, yet everyone seems to ignore it.... Probably as most don't understand it at all.
i think it may be that 3d mappable ignition systems are more than the price of most of the cars these things are going on..:blush:
