Smokey manifold?
Robert
Ok, I went to fit a manifold from Frank, but I had a stubborn bolt and gave up!
So the standard manifold is still in place and I've tightened it up in position.
I started the car again just to check it still worked and the manifold is smoking quite a bit.. Any ideas why? I'm pretty certain it's all done up tight enough!
Could it be just dirt burning off the manifold?
I haven't put the heatshield back on, could it be i usually just don't notice as the heatshield colvers it?
:S
i left it running a while and it seems to be reducing in smokeyness, guess thats that one sorted.
Still pee'd off about that bolt though :grr:
I did this job last weekend, i removed the 1st cat and manifold together and then separated them on the ground and it was much easier.
