Gear Problems
Hi guys,
I have an R reg micra 1.0 passion, The problem is that when lifting the clutch after changing gears the car jerks a little, as though im lifting too quickly but im not, this only happens 1st thing in the morning (after i have driven it a bit it doesn't happen).
Another problem is the gear stick gets jammed in 1st gear (again usually in the morning - when car isn't really warmed up, after a while no problems)
Was wondering wether it was a gear box problem or clutch?
Cheers!
It's pretty normal mate, don't worry about it.
MY CG10 done it
my CG13 does it.
I don't worry about it, although mines 2nd gear usually.
it should last the life of the engine though......
although ive just changed mine twice in two days.....bleedin drive shafts,, GRR
