Porks bike carbs and boost project
Think I'm gunna try this strip....
.....also supercharger mount 3.0, try and bend that you bastard
Finished up new bypass valve which is operated by a 7psi actuator .....
Quick vid, opens better then this now
On supercharger outlet.....
Then this gets plumbed Into turbo
So now it's s/c > turbo
The bypass valve will regulate s/c pressure and also be a direct inlet for turbo, there's no clutch this time so the s/c will also vent to atmosphere thru this, to reduce drain if power from s/c
Why do I never wait/research properly lol
Just received the air con model alternator bracket, I thought it was small, but it's huge, but in a good way!
So I'm scraping my mount.....again..... And making it up on this, it's bang on for the size of the charger
Haha, I keep chopping them up, free metal.
Can't believe how good this bracket fits!
Wish I knew about this when I first come up with idea of using the charger!
I need to drive to the workshop to make a new sump return
How long can I drive the turbo with no oil going thru it?
It's bit that far, I jus dint wanna disassemble again
Today I managed to reposition the oil return on the sump and mount final bits of supercharger
Started it up......no belt slip :) !
Sounds badass!
Took it for a spin, but the fuel map is all over the place now so need to do a few hours with auto tune when the laptops plugged in.......if the mrs and baby lets me out that is lol
Only getting an hour or so a week to play now ;)
Oooh and do some wiring as I left these resting on turbo! All went bang.....but that's why we have fuses, nothing's damaged, phew
Not a good day!!
Been for a drive....it's awesome, that's that.
Then I stripped the belts
Managed to get to a shop before battery ran out and over heated! Water pump belt had 1 rib left
So changed belts on the road kol
Then a few speed bumps later smash in the exhaust......this happened!!
How hard are sills to fix ?
I wanna swap my engine and gubbins over to a better shell, found one going for £200, good car, But about 10inch if sill is rusted, apart from that it's ok
Basically same as any welding but it depends how far it's gone on the inside as for how much time it'll take...i replaced the k11's on mine without any issues.
SC sounds insane, can't even hear the one on mine :D
It was jus the sill that needs doing on it.
And 2 mins round the corner from my house.
Mines got a crumpled up arch,
A lot more work to fix mine than this other one. :)
Managed to replace the meted wires this afternoon
Tucked them away and shielded it with some heat reflective tape
Drive home with no exhaust, stupidly loud!!
Beings it's off, gunna put a mid silencer on and try and tuck it further up.....raising suspension is not an option lol
Going through stuff on the laptop, the most my pedal opens the throttle is 80%.
How can I extend the travel of the pedal? Bend it, cut home in the floor?
Have you had someone press the throttle whilst looking at the butterfly?.... Might sound stupid but maybe the throttle is open 100% but not being registered
