PollyMobiles Rebuild
OP
OP
pollyp
pollyp
welded new mounts on the base beam to lift the printer and regain full Z-axis travel.
rebuild the frame, keeping it square as I tighten the nuts
building the X-axis assembly. all the 8mm leadscrew holes have been enlarged slightly so it spins alot looser
all assembled & moves nicely
some wiring needs redoing (extend the extruder cable. the pwm y-splitters only have 1 end with 4pins and the other with 3pins so will have to rearrange them)
and once fully working, it needs realignment & retuning but overall it looks mint :cool:
OP
OP
pollyp
pollyp
If you can buy them separatly you could probably make\print your own 3d printers n sell em. These printers reproduce :eek:
getting the makibox kit was a worthwhile investment to learn tons bout operating & designing my own printer.
some say time & money = knowledge & power.
now with this knowledge, if I myself was to start all over again into printing, yeah it'd be more economical to purchase all the bits seperately and build it myself.
technically my printer is purely at a experimental prototype stage, built from a prototype machine as a hobby :p
so nowhere near commercial readiness cos that requires a much higher level of quality control with a fixed-design accurate frame.
aye self replicating machines, much like biological cells :cool:
OP
OP
pollyp
pollyp
ah bollux it didn't work.
I tried to connect the dual X/Y motors to the controller with y-splitters to test it and found some major issues.
the makibox D8 controller obviously only meant to run single step motors, so there's not enough juice to run 2 motors and overcome any mechanical friction without it skipping/missing.
the y-splitter lengthens the wiring abit which weakens the voltage to the motors and further worsening the weak signal.
bummer, unless I get a new controller that supports dual motors and start from scratch, this has been a wasted effort cos I failed to check if the board can run 2 motors :/
well this printer frames gonna gather dust and I gotta revert back to my last printer layout, rebuild that all over again :rolleyes:
OP
OP
pollyp
pollyp
so essentially build an amp for the stepper motors? I got few old motherboards, wonder if the mosfets in them will work. no idea how to wire em up yet
OP
OP
pollyp
pollyp
ah I almost had it working after figuring via code how to raise the step motor max current from 1600 to 2000mA, increase something called "current sense resistance" from 100 to 120mA and reducing the max travel speed from 4800 to 2000mm/h via command lines and it spins both motors without skipping
but then found the leadscrews are mounted slightly wonky on the motor shaft making the hot end shake so this design is dead in the water. tis a case of 1step forward 2step backwards, ah well :/
OP
OP
pollyp
pollyp
from another thread I just added up all my spenditures to value kasandra and to simply turbo her costed me £2875
but then I added everything else from forged pistons, LSD, coilovers, etc and ohh my, it ran over £8k :eek::eek::eek: plus burning £2k of fuel & £320 engine oil annually
geez christ why am I driving this mobile bank as a daily?
OP
OP
pollyp
pollyp
so the new frame was quickly dismantled to be stored/thrown away in garage
and prev layout rebuilt and working again
this morning i had a meeting in sheffield so the office had already got my tickets for 9am train from middlesbrough to arrive at 11am (originally wanted to drive there in my car but meh, work policy) and my other colleage would join me at yarm station.
So, you're another from the North East? Can you remember what length of red battery cable you used for moving the battery under the passenger seat? Thinking of doing this with my autotesting K11
OP
OP
pollyp
pollyp
took out the passenger seatbelt reel to check why it's not returning
the explosive side can't be open easy
lets look at this side
pushed out the lockpin
it's just the inertia lock mech
when lateral force moves the weight, it pokes the latch out to trigger the stopper
not much I can service there but somehow after bolting it back onto the chassis, the return spring works again, meh
also recently noticed this rear seat latch had some issues locking
found out the bolt holding the lock to the frame has come out
it's such a tight space but eventually tightened the bolt back up and it work fine again
OP
OP
pollyp
pollyp
Disassembling BC V1 rear damper
wanted to strip apart the broken rear dampers to have a look.
the top cap unscrews. the seal & housing is held captive by a c-clip and can be nudged down the tube but felt springy so there's definately still some nitrogen pressure remaining.
don't wanna remove the top without depressurising it or else the nitrogen will simply ram any remaining oil out onto my face :p
so at the bottom is a grub screw, removed with an allen screwdriver
no oil gushing out yet, but now it abit puzzling what this is. thought it was a ball bearing sealing against an o-ring so I poked it. it felt very spongy and still doesn't release any gas/oil
so resorted to drilling a tiny hole to pierce the tube & released all the gas
now I can push the top housing down to expose & remove the c-clip
top housing removed
piston shaft assembly out
the free floating piston was deep inside so I need to get at it from the other end. figured I could unscrew the base mount off with a pipe wrench & lots force
so I can push this bottom cap & floating piston all the way through
removed floating piston
and the bottom cap
this was the sealing rubber bung that I couldn't push
not much oil was left in the damper
removed the shaft seal
all the damper & piston disassembled. will soon measure & model all the bits :cool:
OP
OP
pollyp
pollyp
did ya take things to bits when ya was a kid lol i did :D
of course :p:D
whether destructively or not.
tis the best way to learn how stuff works, how they're designed & made, how to use tools, how to fix em and how to reassemble them better.
as a kid we obviously start off breaking alot of things but over the years with more knowledge, skill & experience we then begin to have a higher success rate of reassembling/fixing stuff.
OP
OP
pollyp
pollyp
BC V1 Rear Damper Components
here are all the parts of the dampers
top cover
piston shaft guide with brass bush
rubber top out stopper
top out stopper mount
the piston main seal has this expansion slit
there's also these tiny piston bleed holes which I guess are for low speed moves
removed piston seal
main piston
floating piston
bottom cap with the nitrogen gas fill hole
lower mount
modelled every part in CAD
this is the top section with shaft guide & oil seal
main piston assembly
the adjustable dials control the amount of oil bled/bypassed past the main valves
bottom section
during bump travel the oil flows through the tiny piston bleed hole at low speed and through the multi-washer bump port valve stack (like a leaf spring) at high speed
during rebound, some oil flows through the piston bleed hole and some through the other rebound port valve stack
when I unscrew the damper dial to soften the setting, it opens the bypass bleed port so at low speed, some oil would flow through the bypass port as well as the tiny piston bleed holes
at higher travel speed the oil can't flow through the bleed ports fast enough so the oil begins to flow through the main valve stack
when the suspension goes beyond bumpstop and literally bottoms out the damper, the last thing the shaft hits is the floating piston, which offers abit of cusion from the nitrogen gas. any further force would cause the floating piston to crash down onto the bottom end with some damage.
when the damper tops out, a rubber stopper cusions the piston assembly from striking the top cap section
Hi Paul
Great strip down photos and CAD work, I'm surprised you didn't do an animated one too haha, I seem to have missed though where the damper failed because the last I read on this post your car had just passed its mot.
I know you put your car ( and suspension ) through its paces what with all the track days and long road trips and such, but how long would you say you have had the BC suspension ? And would you say it's been good value. I notice you drilled the damper body to release gas pressure, but if the seal had failed and oil was leaking out wouldn't the gas have escaped too ? Or where you just being super safe
OP
OP
pollyp
pollyp
Hi Paul
thanks steve :) hehee I could've animated it all but would take abit more work moving the valves and I was only curious bout it's construction. now moving on to building the new 3d printer.
twas back in april where I discovered the rear left damper was all wet.
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-128#post-718007
conclusion was the hardened chrome coating on that piston shaft within the working ride height range had come off for some reason (manufacture defect or normal wear tear? the other damper was perfectly fine) so the rough surface damaged the oil seal allowing the pressurised nitrogen below to force most of the oil out the oil seal.
I've had these coilovers for over 4yrs, made protective covers since day1, used daily in all weather, long road trips, afew dozen full day hard trackdays, many thous miles.
reliability-wise apart from that faulty left damper which I think is a chroming defect, and worn strut top pillowballs which is expected, the rest of the suspension is still working flawlessly after all that abuse.
so is it worth it? for definate 100%
when the shaft oil seal failed, the nitrogen gas down below only pushes the floating piston/oil out the seal till theres not enough pressure to force any more thick oil out the tiny gap.
I felt the top cap was abit springy so there's still pressure inside and it's obvious we wanna depressurise it before opening otherwise I'll get oil spraying all over.
I had no idea of how to release the gas at the time and now we can see it's pretty difficult, that rubber bung is on there tight. the alternative destructive safe way was to drill a tiny bleed hole followed by a bigger hole.
Hi Paul
I'd also recommend them, I've done 3 years of rallying on mine and there's been no problems at all :) very adjustable as well.
@pollyp .... Whilst I'm here, how low will the rears of yours go? Mine won't go much lower than say a 20mm drop.
OP
OP
pollyp
pollyp
when I remove the springs, adjust damper mount to it's lowest point, jack up the axle till it's literally resting on the bumpstops,
the 15" rim would be 67mm from the arch / 277mm wheel centre - arch (83mm drop).
my static ride height is 100mm rim - arch / 310mm wheel centre - arch (50mm drop), 33mm bump travel
https://www.micra.org.uk/threads/pollymobiles-rebuild.35251/page-32#post-472341
OP
OP
pollyp
pollyp
Yeah... Odd. Defiantly not a coilovers set up for 'mad lows' or 'stance'!
nope these units are designed more towards performance & comfort.
cos of the extra length of the adjustable lower mount to allow the user to adjust bump / rebound travel for max performance, max comfort and prevent tyres from fouling the undercarriage whilst also providing enough stroke travel to maintain tyre contact, the geometry of these tall rear dampers limit how much the chassis could be dropped towards the axle beam.
check ur dampers travelling fully down and use the shorter BC bumpstop and not the thicker original micra bump covers
I'm definitely not on the bumpstops :)
I don't want lows for rallying anyway, it's just something I've noticed when I lowered the car fully for Japshow.
The long damper travel is brilliant for rallying though, allows them to keep grip on the rutted surfaces :)
OP
OP
pollyp
pollyp
have you tried verifying ur suspension geometry can reach the bumpstops by jacking the axle up without springs or panhard connected?
if the cars weight can't push the unsprung suspension down to the bumpstops then something in the geometry or bushing is binding. loosen all trailing arm inner bush bolt, position suspension at new ride height then retighten the bush bolts to reseat the inner metal bush insert so the rubber bush ain't so twisted/binded.
if the unsprung suspension can drop on the bumpstops (assuming that the ride height at point where it rests on the bumpstop is lower than ur target height) but when the adjustable rear spring seat is set fully down and the ride height still cannot reach ur target height, the main spring is either too hard and/or too long.
either soften the rear spring rate or reduce the free length of the spring (custom made, custom reformed, or unadvisibly cut it which will raise spring rate too)
adjusting the panhard rod to fit & keep the axle centered at the new static ride height is the last step
Thanks Paul!
Lots of bits for me to tinker with over half term (week off school, woo!). I'll update my blog with results when I get around to it.
OP
OP
pollyp
pollyp
Since the printers original mechanism of using intersecting rails was prone to being too slack or binding,
and the parallel dual motor design required too much current from the control board, hard to keep aligned and leadscrews were wonky,
now I spent afew weeks redesigning it from scratch going a different route by keeping all the XYZ motors/sliders seperate, using stiffer 8mm rails, mount the Extruder motor over the hotend to eliminate the bowden tube and all the leadscrews are aligned inbetween the linear bearings so they move the assembly via its CoG to reduce any binding.
Printer 26
Extruder motor & slider rails aligned vertically & Z axis motor pulls the frame from above but during movement the leadscrew would foul the Y axis assembly & pulls the frame from off-centre.
Printer 28
Z motor pointing upward so the leadscrew doesn't foul with the Y axis assembly. Stiff thin frame keeps the CoG of all the Y / Z axis & Extruder motors aligned but access to the Y axis motor was blocked.
Printer 29
Cleared the frame for accessing the Y axis motor but there's alot of wasted frame space.
Printer 30
Z axis bearing mounted slightly offset to clear the Y axis motor for a shorter chassis frame but the Extruder motor mounted top-heavy high above rails could cause binding. half upper main frame support as an attempt to save material.
Printer 31
Changed to full box frame for rigidity.
Printer 32
Mount rails horizontally with leadscrew under the Extruder motors CoG to reduce stress but assembly would cover the bed
Printer 35
Swapped the hotend to the front for easy access and unobstruct the bed. Develop new pull-type extruder tensioner.
Printer 36
Utilising longer LM8LUU linear bearings for reduced binding. One used for aligning the mounts Y/Z axis while other bearing is only for the X axis. Extruder motor fan mounted at the rear.
Tried printing the mount but the long print in cool room temps developed alot of serious splitting.
Printer 39
Mount the Y axis motor closer inward to utilise more of the available screw thread. Extruder motor fan mounted to the side. Linear bearing for the heated bed frame mounted further inward to clear the beds adjustment screws.
Printed the mount but it still cracked, so I manually filled the cracks with hotend, grinded & smoothed but concerned bout the amount of flexing between the two long linear bearings.
OP
OP
pollyp
pollyp
Printer 40
Added some bracing between the two linear bearings and tried printing it with an external shield to help control heat & cracking, but it still warped.
Printer 42
Stiffened the rear of the frame to stop it swaying.
Printer 43
Moved the Extruder motor inbetween the sliding rails vertically with the leadscrew below but the big offset distance between the bearings could cause binding.
Printer 44
Rearranged the sliding rails & leadscrew to be close as possible together vertically to reduce binding & space and turning the Extruder motor sideways to keep its CoG close to the rails.
Printer 45
Tried adding an extra tube across the top of the Y axis frame to support the Z motor rather than a thin plate steel but the 15mm vertical L bars holding the linear bearings were too small.
Printer 46
Construct a small tubular frame around the Z axis motor to secure it solidly.
OP
OP
pollyp
pollyp
With the design finalised, time to build it.
Ordered some 8mm bearings & rods.
Printed & smoothed the new hotend mount.
Was looking for a stiff coilspring over the M3 screw to tension the filament extruder motor pulley, found some from ball point pens. Tried running the extruder but the springs were too soft and the gear slipped so resorted back to a piece of rubber.
New hotend mount with bearings, tensioner & leadscrew nut.
Cut some 16mm square tubes as accurately as possible.
Used a picture frame as a jig to keep it all square, made the base frame
Then the sides
and welded it all together
To make the adjustable rod ends, cut some 10mm tubes
and weld em to M6 nuts
All the frames complete
OP
OP
pollyp
pollyp
Assembling the Y axis frame
Fit bearings on the bed frame and onto the main frame
Install Z axis bearings
Followed by the Y axis frame
Fit Y & Z axis motor
Fit extruder motor
Trim the old bowden tube this long to fit in the mount like this & locked in place
Organising all the wiring route
Hot glue the end-stop switches in
and yay hey presto a very fine piece of 3D printer :cool:
Began afew test configuration prints and ohh boy she prints sooo straight & accurate now it's awsome :):D:cool:
This piece would've been near impossible with the old setup but it's now possible
OP
OP
pollyp
pollyp
Very nice work Paul, I'll have to get you to make me some random stuff haha yeah
it's like when u just learnt a new skill to weld, cut,fabricate,program, etc you just can't wait to see what you can make.
only limited by ur imagination and how well u can model but it ain't a cheap hobby with all this ££ rebuilding & tinkering but abit more affordable than playing with special car bits
I've done it before, years ago albeit, still have solid works at home.... I'll have a play later :)
So the cars gone on hold for a bit i take it? Keeping it as it is for a little while
OP
OP
pollyp
pollyp
yup she still works fine enough to get me around, we had our fun for the yr so its just maintaining her over the winter while I now focus is purely on sorting out my career & income before considering spending any more on her.
cos of her high parts value, high maintainance, high risk & running cost, I may have to consider getting another car preferably k11 as a normal eco daily parked on street for when I have to move away for work.
SuperUno
Buy & Sell Member
With your ability to create such CAD drawings you must be able to get a job somewhere using those and your engineering skills...
OP
OP
pollyp
pollyp
tried printing these slim plastic clips to hold down the glass bed rather than the bulky metal clamps
they hold briefly but the high temps make em soft n loose so went back to metal clips
replaced the loose bolt & spring bed support with nut & bolts to reduce any slack in the bed movement
my glove box latch needed replacing so printed another one
wanted to finally enclose the printer to retain heat and reduce the amount of ABS plastic shrinkage/warping/cracking on big prints so got this 4mm double wall polycarbonate roof sheet from B&Q that's stiff, insulating & kinda translucent to look through
cut the panels to fit over the frame. propped the filament spool on top
fed through a hole
power & usb plugs through the rear holes
printing at the mo and it does a good job keeping it hot inside
wehey
Just out of interest, what are the running costs of a 3D printer like?
I used to be a 3D Cad draughtsman and have been interested in giving this a go for a while.
