PollyMobiles Rebuild
OP
OP
pollyp
pollyp
Just out of interest, what are the running costs of a 3D printer like?
I used to be a 3D Cad draughtsman and have been interested in giving this a go for a while.
just updated my cost spreadsheet:
upfront capital, the makibox A6 kit first costed me £255 (would be cheaper if I'd known to just buy the board, motors & heated bed separately),
adding the cost of filaments, acetone, bearings, rods, E3D nozzle, making the frame, polycarb sheet it totals £472
each 1kg spool cost £10 and est running cost over 30 prints, each print would cost from £22
OP
OP
pollyp
pollyp
Case defo smarts it up. Gets some neons in there.. Serious.
Sent from my Nexus 6 using Tapatalk
Would make a cool ambient light in the room if that makes sense
and a disco ball, n flamer heating kit, n lazer guiding n bells whistle notification too :D
yea I like the sharp look of the ribbed sheet giving it a modern look.
...actually looking back at it, it looks like those ribbed effect glass u used to see back in the days on doors, cutlery doors, bathrooms, office privacy windows.
I'm gonna put those bright LED strips along the frame to light up the bed surface n make it easier to visually level the bed & see how it's printing.
may need to cut a "peekaboo" hole to look at the print while it's sealed cos that ribbed polycarb roof sheet is like looking out through those distorted bathroom window glass.
lighting up the room is a byproduct, but it's friggin noisy enough too so defo won't be sleeping in the same room.
now that it's enclosed, it could prob be relocated to the colder garage.
OP
OP
pollyp
pollyp
prints smoother with the enclosure but first 3mm warped abit, maybe cos I didn't apply ABS juice onto glass so it lifted slightly to disturb the few layers, or the bed was too hot
refine the finish till they fit
fit screws to secure the knob
trimmed the screw so it doesn't obstruct installation
fits nicely
imo I don't like this lock design cos the weak plastic clip is easy to be popped out if you slam the glovebox closed, so gonna redesign it soon.
OP
OP
pollyp
pollyp
the vibrations from the solid mounted stepper motors tend to resonate through the steel frame like a speaker so to isolate it I needed some 3mm o-rings, which was difficult to source locally on a weekend without buying a whole assorted boxset.
instead while browsing through wilkinsons, found this £1 pack of kids foam shape that had bout the right size thin foam circles I could use as foam washers
fitted the foam betwwen the screw/frame and motor/frame on the XYZ motors
and it's helped muffle half the noise :cool:
OP
OP
pollyp
pollyp
reprinted another catch can top last night for 6hrs with the fine 0.25mm tip and hot enclosure, the result is a very clean accurate print with zero cracks or peeling
break off all the support structures
and after smoothing in acetone it looks silky smooth, no gaps in the layers and gas tight
the bores inside are also smooth & sealed
and all the joining lines are rounded
removed the old top, melted abit
captured abit of vapour after a trip to manchester
think it's leaking cos this cardboard seal gets saturated in oil & leaks. need to replace with a rubber seal
fit new catch can top
OP
OP
pollyp
pollyp
the tomtom satnav rubbish mount also broke so modelled & printed this to test I got the tolerance correct before finishing the rest of the mount
disassembled the printer, attempted to straighten the slightly wonky frame but some bits began to buckle so only did abit.
welded a top reel support,
drilled afew screw holes for the panels and painted black :cool:
I like stealth black :p reassembled with neater wiring
screwed the panels on rather than messy tape, looks much neater
fitted spool, levelled the bed and now printing the new satnav mount :)
OP
OP
pollyp
pollyp
after verifying the shape of the satnav mount fits, the next print is to test it can hook onto the locking clip, plus feature a flat round base for the separate mount to glue onto
slips on nicely
but the lip was too short
a bigger issue is the fragile upper section which could easily snap off
disassembled the suction cup, modelled existing parts
and remodel the new suction cup mount, removed the weak upper section of the satnav mount
printed overnight with gr8 result
removed the support structure
the suction parts still fit
bond the mount together with acetone
smoothed it all together :cool:
the cam handle had digged abit through the soft smoothed surface but the suction cup still works
finished satnav mount :D
OP
OP
pollyp
pollyp
clearing up the garage, gave these old grooved diamond black GTIR discs a wirebrush n put on buy sell
and the old janspeed catback
two scrap engines definately binning, grabbed all the useful bolts of course
two sets of 1.3 cams for the buy sell. interesting to know that both inlet & exh cams are exactly the same and only difference is the sprocket locating pin that's 72deg offset
one of my fav past time, destructively disassemble old parts to learn bout the inner gubbins before binning em :p
Inside a Micra fuel pump
cut the outer crimp off
and pulled out the DC rotor which has been moulded to be streamlined for the fuel to flow past. the +ve displacement pump flows as arrowed
fuel flows past the gap inbetween the outer permenant magnets and out the centre of the back port. there's a sprung pressure relief valve incase of blockage
the rotating assembly of the pump. interesting to note the streamlined rotor spins on brass bushing around the static axle
rotor with a coupler lugs at the front
pump impeller like a lego tyre
fits in the pump housing
and there's a separate plastic coupler to isolate the motor vibration from the impeller
notice the two tiny bleed holes. perhaps to bleed any trapped air out?
Inside a boost solenoid
here's the old volvo solenoid I used for the DIY boost controller
cut it open in half
and the simple internal valve mech. there was a spring inbetween the valve & stator but it popped away
the moving valve has a two sided rubber bung in the middle, metal outer casing for the electromagnet and vented plastic spokes inbetween for air to bleed past.
very simple how it works.
when the solenoids ON, it pulls the valve towards the electromagnet which blocks off the compressor line and exposes the WG line to ambient air and keeping the WG sprung shut
when the boost controller/switch detects its reached target pressure, it turns the actuator voltage off, allowing the return spring to push the valve closed the other way like this so that boost pressure from the compressor can now reach the WG to regain boost control
OP
OP
pollyp
pollyp
redesigning the glove box lock. measured & model the holes
new housing & knob
housing inserted from inside the glovebox
twist to lock
and the screw both locks the housing and the handle
printed
clean up prints
smoothed to strengthen the skin
assembled like this
installed on the glovebox. it works but needs minor refinement later and printer needs recalibrating
OP
OP
pollyp
pollyp
recalibrated the printers axis and printed this pyramid with 5mm steps to verify it's accuracy across a range of travel
something i always fancied doing and twas inevitable was to print a K11.
imported a model model from sketchup into 3dsmax and had to spend several hours refining every surface till it closely matches the scematic & photos (tis also a great way of understanding the detailed shape & curves that defines the micra)
printed a small test piece without wheels
it's so cute. forgot to add the front bumper mouth in this one
added the missing bumper mouth & handles/indicators & printed it bigger scale with wheels over 5hrs
removed supports
the lower part of the wheels that had alot of challenging overhang with minimal support structure didn't print right so I'll need to print the wheels separately but all the detailing of the grills & handles turned out great :cool::D
OP
OP
pollyp
pollyp
remodelled the chassis into a 5dr, added a raised bonnet, panel shut lines to highlight the contours
added a rear spoiler & boot handle. starting to look like mine now
plus my rota grids :cool:
printed the body
ooh the detailing appears fab, extra hours of refining all the edges was worth it
even the spoiler worked out
raised bonnet
printed the wheels, trying to recreate the rotas at this tiny scale is a challenge for the printer
glued to the body
and eey look at that :D a vast improvement from the previous print
close resemblance, only forgot the big exhaust :p
OP
OP
pollyp
pollyp
guy pm'd me on fb if I could make some granada wheels for his scale models
modelled the wheels one night, includes vent holes
but when I tried printing, the thin walled ABS tended to shrink alot n buckle and the middle shaft broke off
so tried a thicker wall but still buckles
the detailed face printed fine but the bed had shifted offset
had to split it so the detailed face bit is printed close to the bed while the thicker solid base retains it's structure.
face printed fine
solid base with less buckling
glued together
he also wanted these tyres
so modelled
printed
the diagonal grooves came out but the two grooves along the grain didn't have much support
tolerance fitted the wheels together.
one set of wheels complete
OP
OP
pollyp
pollyp
sister likes Simons cat so for her bday wanted to make a little model for her inspired by "Mirror Mirror"
sketched some elevations to help plan the profile shapes
crafted the shape in CAD over several days
printed this massive dual figure model, took 9hrs
popped off the bed without snapping anything
removed the supports
smoothed the surfaces
painted the black features with a pen
printed the remaining mirror frame & base
and hey presto a real interpretation of Simons cats Mirror Mirror :D sister luvs it
OP
OP
pollyp
pollyp
Tyre sizes for accurate speedometer on K11 Micra
Since the speedometer gauge requires a specific rpm of the speedo cable (or electronic speedo pickup on facelifts) for each mph reading, the ideal outer rolling diameter of the front tyres for accurate readings should be approx 576mm dia
Afew things to note:
  • The amount of tyre sidewall deformation under the cars weight from either under-inflated tyres or soft tyre construction or excess weight could result in slightly smaller rolling diameter
  • This list assumes the wheel width is closely equal to the tread width to maintain a square straight tyre sidewall thats perpendicular to the tread, so this excludes stretched tyre fitment
To reach close to 576mm outer diameter the required tyre profiles are listed below:
155/80/13
165/70/13
175/70/13
185/65/13
155/70/14
165/65/14
175/60/14
185/60/14
155/60/15
165/60/15
175/55/15
185/50/15
195/50/15
165/50/16
175/45/16
185/45/16
195/40/16
165/40/17
175/40/17
165/35/18
Not sure I get you with this one Paul. Do you mean in an ideal world, as those are quite a way off manufacturer fitted sizes. ie my recommended size from factory is 165/60/14.
The manufacturer recommended tyre size is based on the speedo over reading, all cars are designed this way so you less likely to be speeding by a couple of mph i.e your speedo says you're doing 30 but you're actually doing 27
OP
OP
pollyp
pollyp
Just as Karl says the manufacturers recommended tyre size tends to overspeed the speedo abit, perhaps intentionally to reduce accidental speeding or by law?
Yes the list are calculated ideal targets to aim for to get 100% reading.
So ie for 165mm width & 14" wheel, the sidewall profile should be nearest and under 67%.
Since tyre manufacturers only size profiles in per 5% increments and the nearest available sizes are 165/65/14 and 165/70/14, you choose 165/65/14 so that it reads closer to 100% but not over it.
OP
OP
pollyp
pollyp
chogy was thinking of selling his SLX for £500 no tax no mot, gonna check it tomorrow.
I just checked insurance quotes online and wtfh is wrong with insurance!?
currently paid £450 yr fully comp at sky for kasandra.
now if I brought this 1996 SLX and insured it seperately with just exhaust mod and 2cars at home it's least another £700!
if I only insure the single standard SLX with exh mod and sorn kasandra its least £720!!
if I just insure the single SLX with zero mods, the price jumped off a cliff to £300-500
bloody hell this is extorsional and could be a real breaker :/
I'm gonna ring Sky and see how much extra it'll be to add another stock car with kasandra.
if it's an extra £300+ then I definately can't economically afford to insure 2 cars.
insurance sucks
OP
OP
pollyp
pollyp
Even I can insure a modified micra for cheaper than that! Only 400 for a lowered, exhaust, intake etc
just doesn't make sense. if those quotes r anywhere close to the real price, it costs twice more to insure a 1996 standard SLX with just an exhaust than kasandra with insane mods? o_O
all this ncb stuff seems bollucks
OP
OP
pollyp
pollyp
oh ffs wtfh, I just rang my insurer adrian flux for a quote on the stock SLX with exhaust.
cos kasandras policy is already running, the turquoise SLX will require a new policy quote.
gave em all the details and to my shock they quoted TPFT £478!! which is £3 more than my fully comp cover on kasandra. watt the phok.
ok rang sky and simply hilariously they quoted me their cheapest is urm over £1K hahahaaaaaa
I mean really, whats the point. even with 9yr NCB on 12yr clean license, it costs me upto twice as much to insure a newer 1996 SLX with just a backbox than my older 1994 SLX with friggen every mod in the list!
so yea basically its a no-go for buying this nice standard SLX. dammit this missed oppurtunity saddens me again.
mind blown given up blaaa.
Thats weird Paul, i know fully comp is usually cheaper for us on the IOM as insurers prefer that over TPFT.
I have a policy with my GF for her micra with me on it and thats only £280 per year! crackers and she hasnt passed her test yet!
OP
OP
pollyp
pollyp
tried my luck again with trying to insure Chogys SLX only to get knocked down again.
last night ran afew quotes through comparison sites and figured that with 9ncb, work as food prep in takeaway, 7000 annual miles social off-peak use (since I live next to takeaway), completely stock micra, Octogon insurer quoted £370 and Direct choice at £400. an OK realistic price.
chogy says he can sell with stock exhaust & wheels for round £450, looking more achievable.
so rang Octogon, no answer. googling em in forums says they're a really dodgy poor service insurer so gave it a miss.
rang direct choice, verify details with guy. cos NCB can't be shared, if I transfer it from kasandra (imagine kasandras premium with 0 ncb haha) over to the blue micra he quoted £667.
if I kept the NCB with kasandra, the blue micra with zero ncb would be over £1k ey? is GoCompare cheating?
all other companys now closed for new years but once again dissappointed.
my situation pretty sucks. cos ncb can't be shared, my options are either:
- insure kasandra with 9yr ncb for £475 kept at home & drivable PLUS blue micra with 0 ncb at £1k for new job elsewhere,
- or only insure the blue micra with 9ncb at £670 for new job outside and never use kasandra again SORNd & rusting at home (parents won't like it) :(
- insure & risk parking a £8k turbo kasandra on street somewhere as a daily commute to my new job! (no way) :eek::confused:o_O
- wasteful cost & time converting kasandra all the way back to standard form before finding new work? (no point) :confused:
seems I'm stuck with kasandra forever
wehey
Just put some kak old steel wheels on Kasandra and drive her daily.
No one will know she is worth 8K ;)
OP
OP
pollyp
pollyp
The appearance ain't a prob, she's abit subtle. It's the high risk of losing over 8k stuff if she was damaged or nicked out in the open street.
Being realistic, I may have to compromise SORNing kasandra into storage for awhile while insuring & driving a boring standard car for work till I can financially support both cars.
OP
OP
pollyp
pollyp
More I look into it, more it seems unfeasible to insure a highly modded kasandra with any other car.
Read some insurers support multi-car but only permit very limited amount mods.
Have you tried to insure any other cars apart from Micra's? I've found that Micra's can be quite expensive to insure compared to other cars. For example when i bought my Volvo (just to use as a daily) it was actually cheaper to insure than my K10!
I've found the same, the micra is a high risk car
