Same here so I need to do double check with diameter. Can anyone verify for me please? Btw my micra is 1.3 prefaceliftAm after both sides my self mines preface 1.3 if am right I think preface shafts are 40mm and 1.0 facelift is same, @frank
easy would be checking how thick ur shafts are 40 or 38, if u have ur shafts on car u can check with calibrater tool. I don't have any shafts at on to work from that's whySame here so I need to do double check with diameter. Can anyone verify for me please? Btw my micra is 1.3 prefacelift
So it's spine patten or thickness am looking for ?the gearbox spline is what you have to check azzy
both mateSo it's spine patten or thickness am looking for ?
can't I get the cv joints from motor factor with my full reg and then take full size and thickness from thatboth mate
dunno mate, shafts are a bit of a minefield in terms of getting the right onecan't I get the cv joints from motor factor with my full reg and then take full size and thickness from that
Remeber frank I only need the right hub size shafts not for the gearbox side loldunno mate, shafts are a bit of a minefield in terms of getting the right one
Can remember I used 27mm nut on both sides so if both cv fits my hubs I'll be ok ? It's cut and shut so need hub spines rightthe hub splines are all the same azzy, but there are various different bare shaft splines and 2 different diff splines
