Dr Zoidberg said:
looks very tidy
how hard was it to mod the standard manifold to fit to the turbo? would love something like this
dead easy as long as you can arc weld (mig/tig cant handle this).
I cut mine just under the threaded bit that holds on the heat sheild and welded on a stainless steel plate to bolt the turbo to. you have to use proper stainless rods, or it will crack.
You also need a gasket for between the turbo and the manifold, bet one i found was by going to my local scrap metal dealer, and cutting a square out of an old copper boiler. i made a template of the shape from the turbo, and cut it out. bingo, mega cheap, working copper gasket.
I got my stainless off ebay.
oh, turbo size is really improtant too, go too small and it will feel like an turbo diesel, go to big, and the lag will spoil all your fun.
I went for a T2 from a renault 5. perfect size, will give you up to 17psi, and really easy to plumb in.
