Antony
help...
i have a problem. here are my symptoms.
start the car no problems hot or cold.
set off in first, sometimes is jerks sometimes it doesn't
second the same.... and third
4th gear feels like somone has shut the throttle for me, even when i am at speed and foot flat to the floor.
5th gear will shut the throttle off and slow me down to about 40, then kangaroo's violently.
if i pull over and rev the engine it will rev to 3000rpm and then sounds like a "two step" launch control spitting flames out of the back end... but wont rev any higher.
if i manage to get upto 60mph in third i can hold the throttle at 4000~rpm and it will stay there, but if i go up a hill it will slow down again.............. unless i boot my foot down and then it will pull through to the limiter.
sometimes its fine if i leave it for ten mins, but 30 miles later and its does it again.
checked the throttle solder joints and they test fine..
the dizzy cap was fuzzed up but thats been cleaned....
anyone help??
thanks guys. im going to scotland on sunday night so just a week to sort it out. :glare::glare::glare::glare::glare:
anyone help??
