i cant remember if i cut some bits of tube mate ? some more pics here http://micra.com.au/community/message.php?messageid=69926looks awesome Frank. what did you get the injector seats off? do you think it was leaning out at WOT because of the size of the TB and maf you were using? i.e if i stick with the cg i should be ok?
i just wedged the rail on and tried it out for a couple of hours the injector O rings are a very snug fit lolhow is the fuel rail bolted to the mani? not entirely clear in the picture
Sent from... My phone
and i,ve been running the SR t/b and cutoff stock maf on this current high comp engine for a while now
edit, i think the leanouts were because of the very different shape/characteristics of mani personally, because my current SR/CGA setup runs fine
just go for the high comp/SR t/b/QG injector/CG maf/exh mods setup hoop, tried and tested and pulls like a 1.6ye but i know i will never get around to it lol, i will get it all built up, it wont work properly out the box, cost me more time money and effort that could have been spent on a fast car in the first place lol. may just stick with being low and slow ;D
CGA hoop, but you can us a CG one with 15mm copper pipe in the injector rubberson a standard cg intet?
a 10 quid narrowband gauge mate, very restricted in scope but it tells you if you,re off the scale lean or rich (or closed looping)also what are you using to measure afr Frank?
