'Someone' lolsomeone is planning a 1 litre job
i will see if they can pm you
I had a 1 litre turbo running 116bhp she went well but I got excited with boost and lost a piston
Also i highly recommend 2 head gaskets! No plates inbetween just on top of each other if you cant afford/be bothered with low comp pistons. I used to run 0.8 daily and it was great
I'm surprised you didn't recommend a head skim to go with a CG10 + CG13 pistons Frank, surely that would put things in the right area and still be doable?
Always number 3 frank. With my turbo it was always over/around 120mph+ constant speed that melted mines. Never did i accelarate and it happened straight away
Anybody know why its always number 3??? None of the other pistons were ever harmed
Inlet design I would say. Pushing more air into number3 so ran lean, either that or poor fuel atomisation. Air flow either way.
Purely because would i have even melted a piston if theres wasnt this lean point in cyl 3 eventhough lean is all my car run lol
it was always at 12 o'clock on the piston crown that was melted
If im honest there was a good few things i could have done better but we learn as we go along..........I got 124 BHP from the 998cc...using a T20 turbo....Ga16 injectors....1300 pistons e.c.t........................But i know the engine is still running as a 998 turbo....and is now on 150 BHP as the garage fitted forged pistons and stand alone ecu (Y)(Y)
The car ran perfectly well and made a few long journeys with ease....except i thinnk sumwer along the line the Throttle bodie wasnt responding well and kept having major flat spots........................But that must of been corrected since then as like i say its still going..............
But my advice to you is....dont waste your money.........................If anything buy Mega-Squirt and run throttle bodies from a R1 or similar. (Y)
,has anyone put a turbo off a diesel car onto a micra?or would it be able for the heat and high rpm?
Yeah frank inlet side,
I couldnt possibly tell you mate lol so an ignition problem?
