top speeed!
thing is it was parked up for 9months before that i had it 115 now sines it has bin back on the road it does about 95. is there somthink rong some where??
do u think that could be the problem? i do normal sevice it every 3000 miles. could it be a electric problem?
Well if its been sitting for 9months then I would do a service anyway. Dunno if its causing a problem though
engine is standard it has 14 speedlines on it. so service it and just use it should be ok? Is it worth changing the distrubutor cap
This car had one fitted :)
lol any ideas? somethink fills like its holding it back like ya driving with ya breakin bindin
you could check/ test plug leads+sensors first then move on
but you said brakes binding? see if wheel tempreture is up after a run in the car
fav post so far and the few above:laugh::laugh:
prefacelift's should go off the clock if you can get it there...
facelifts are limited to 120 (on speedo) 112 actual speed iirc
and if k11 isnt smooth at motorway speed,,,,somethings not right! fix him up
lol why would i be drunk humm!!!! like when my car maxed its self at 80 :( although it does feel it may be in limp home mode lol
ive not been for a top speed run in my new k11 but in the old one i used to run it to 118 on the GPS between manchester and leeds on the M62!
