Hello Micramaniacs,
I have mine since 2017 and started to like it more and more the longer i have it. Not as a sportscar but as a small extraordinary comfortable (and reliable) car (especially for its size) that you can rev to the limit every now and then without worrying.
it's a preFL 1.0 from '97 with racing stripes! yes they give +5 HP
(or minus 5)
it revs continously/steady to high revs on low speeds, without torquepeaks, but max speed seems really hard to reach. I barely get 145km/h in fifth gear. 4th gear seems to go easier towards 160km/h (Speedreadings on tachometer, gps might be ~10km/h less). Under the right circumstances the 4th even get's to the rev limiter = ~165km/h
now back to topic:
I already swapped the cams against 1.3 cams. didn't feel a difference. I try to use VMAX to determine powergains. With Both 1.3 cams it feels all the same.
Overall it feels like less torque down below.
I'm often testing full throttle in 2.gear on a closed place where i can go ~20-60km/h. without anyone bothering. Just a few pushes...
the 1.0 Cams seemed to pull better, they could surprisingly push me in the chair. Idunno how that makes sense
What else i tried:
GA16DE injectors. ->no big difference.
new exhaust (muffler) -> no big difference
as of now, i have a magnaflow M6 Muffler (which is surprisingly quiet an nice, despite it's big look) -> no big difference
GA16 Airbox ->get's a little louder. fit a K&N in it, gets a little more louder... but nothing serious, at least nothing that i notice from the inside.
latest: put on a 4-2-1 Header i found used. nothing written on it, no info about it. Has the oxygen sensor between cylinder 1&4. which i don't like an gonna fix sometime.
put it on and it seems to gain a little more power, especially on higher speeds. felt like it get faster to VMAX. but not much.
found out later that it was a little leaky at the connecting Tubes to the cat.
I fixed that for now with some Exhaust paste. havent tried VMAX yet but 20-60pulls -> and there is a problem: It get's damn loud around 4000rpm like Motorcycleloud but it's coming from the front. Not sure if it was the header or just intake sounds.
as it's a dizzy model i tried playing with the Ignitiontiming -> retarding get's louder and pulls worse // advancing the timing gets faster and the rpm range where it's loud decreases
replaced the GA Aribox with the original CG airbox -> the sound is getting quieter.
checked spark plugs (NGK iridiums) they seem to get hot. the white ceramic seems reddish. running to lean?
Of course the old ECU'S don't help much. figuring out the issue. It just shows an AF-Base of 100 (sometime ~105 or ~98) and O2Sensor seems to do fine jumping around like usual.
Idle is "coughing" a little. And not much adjustable since i swapped the cams. Too much vacuum maybe?
The Questions:
1. Is it possible that a little CG10 micra makes loud intake noises after swapping the exhaust manifold? or coud the manifold have a serious leak?
Problem is: it's only loud under load. I can't listen closer while driving.
2. running lean: should i put in GA16 injectors or get a 1.3 ECU?
Or should i even put the CG10 cams back in or only the CG10 exhaust Cam?
As of now, after trying so many things, it seems to me that the ECU might be the best tuning even for stock engines.
3. how good would a CG13 ECU be? might work harmonically with the 1.3cams?
get a nistune or even a standalone ECU. Recommendations?
4. how high could a stock CG10 rev given a good ECU setup? when do Valves start bounce?
My Main Goal is not max power. But a little more spice. Higher efficiency on the way would be really really appreciated!
efficient at low revs an going very high revs if wanted
maybe i should've bought something with VTEC
now back to topic:
What else i tried:
The Questions:
