T
turbomike
Guest
I need to rotate my compressor housing to make fitting my cooler a liitle easier where are the bolts to losen the housing?Also would it be ok to remove and refit the the rad elsewhere and then fit the cooler where the rad used to be in order to shorten the pipes.Does the march turbo take coolant and if so please specify grade also Ed do you have a part number fo the GTI-R plugs.Getting my exhaust made and i think its gonna be 58mm is that ok running 700 mmHg boost?Ed,do you have a conversion for mmHg to psi?I'd like to say thanks to everyone for their advice and helpful suggestions since i joined!
