should this happen??
driving along in any gear and without dipping the clutch, you can move the gear stick into neutral with ease. No struggle, no pressure, just slides into neutral from any gear.
It does not do it by itself while driving, only happens if you move it.
normal or not???
cheers
If you are going the right speed / engine speed you can pop it into the next gear without the clutch.
or blip throttle and you can go down the box
But get it wrong, it sounds nasty!!!
You only have to worry when it starts falling back into neutral on it's own, then it's time to sell up, fast lol
