Got a problem with my rec counter it was working disconnected it now it won't work now it's wired properly?
Can you confirm correct pin on the ecu memorised it but just want to check? Other than what else could it be? Back of dash wiring in, the blue wire was removed as it's a dead wire checked voltage and continuity of it before removing.
Any ideas?
Any ideas?
