hi,
i fitted a set of dials from a micra SLX with a rev counter, i spliced into the blue wire on the ignition pack to get a signal for it , as i dont think my ECU has a pin for the rpm signal, however when i start the engine , the rev counter is steady for about 2 second then jumps around erratically from 1,000rpm to 4,000rpm , anything obvious im doing wrong?
cheers
cheers
