Porks supercharged k11 project
pork
Had a couple of k10's in the past, great fun, but thought I'd give a k11 a go this time :)
Picked up this beauty.....
......auto (which il convert) £100 with years mot
Plan is to use stuff from old k10 that's lying about
Starlet mani with top feed 330cc Audi injectors
Polo coillies
Swirl pot pump and filter stuff
Home made stainless 4-1 mani
Cg13de with m24 supercharger, hybrid cg10/13 clutch I made to go on a cg10 gearbox
Supercharger mani/bracket
After a cg10 pre face lift gearbox
Manual pedals and gear lever stuff too
Where are you pork? I have a cg10 here (south coast between portsmouth and Brighton) that's ripe for cannibalising.
I live in thrapston but work mainly in luton
But could possibly drive :)
Might pick up some starmags tomorrow on the cheap ;)
Does rangerbob on RR still do the bolt on arches?
Also, the engine on this car is shagged, no compression
It's a cg10 auto, so will it be closed deck like the cg13 autos?
Havnt had chance to rip it apart.
If it is, I might give a low comp engine build a go with the corsa 1.4 twinport pistons and cga crank
I think I remember that being right, if not correct me :)
I've not heard bob's arches mentioned for a while, but I'm sure a quick google for the thread and PM to him would find out.
Last time I ordered a set was 3-4 years ago for my first car
Anyone else do then?
Cg10 pre facelift box
Any of those if you have it mate?
Just browsing for gear lever stuff, are the all the same between the models/year, my cars a 1993
Started taking off old engine and auto box......man there's a lot of plugs!
But snug in the bay compared to the k10!
Bit of an update....
What an absolute chore that was to get out!!
Just needs a tidy for my engine to go in
Auto shifter out
Coilovers modded to fit
Sprayed up with some nice black along with supercharger throttle mounts
Should be picking up a cg10 box once scrappy gets of his arse!!
Are the auto drives shafts the same as manual?
If not ok get those at same time
Nah, want the cg10,
Want the acceleration. Lol
Otherwise il need new clutch flywheel and shafts too
Not overly bothered about top end, it'll only be used for blasting around b-roads and maybe the odd small track lol
Had an hour free.
The wishbones were rusted to hell, but luckily had mine from the old car
So swapped those over along with hubs/brakes as mine were in better state
Popped in front coilovers too lol
Got a gear linkage from eBay, it's only got 2 mounting holes on the back, but nowhere to mouth on the front??
An I missing something
Also, never taking there cars apart
Are the back springs easy to tenivr
Rear coilles on....
Pretty much as low as it will go, bare in mind there's no engine in
It won't stay like this, just to see what it looks like lol
Got the nuts off, but bolts won't budge
Been smacking it for ages lol
The top one is the only bolt that is removable the lower is a stud :)
Try putting the rear up on stands then raise the axle so the weight is taken off the panhard
Panhard rod : A blow torch + mole grips + angle grinder + swearing = usually more swearing but eventually it'll come off.
Chances are the metal sleeve that's in the lower bush (maybe also the upper if you're having trouble getting it out) will have rusted itself stuck. Just carefully remove the lower one so you don't damage the threads.
I've got all nuts of ok, the top bolt is completely seized together.
Tried all sorts of breaker bars, mallets, colourful language
Yeah i know i had to cut and grind the bolt flush with the upper mounts and slowly prise them apart to get the rod out. I was swapping everything out though so i wasn't too fussed with how i got it out :D
I can say nearly 100% the lower sleeve with be rusted solid but once you've got the upper out you can pull off the panhard and them remove the bush and finally see wheren to start working on the metal sleeve.
Can't even remember how long it took but it was in the hours...probable took longer as it was one of the first things i started modifying and I was being gentle haha.
Gunna be fitting my standalone ecu and loom this week,
So no need for old stuff,
How much of it can I remove? I don't need any of the engine control stuff, but what else is connected to iy?
Fan? Other car equipment?
You can bin quite a lot mate, but I kept the fan etc in just so I could piggy back into the wiring.
I've a few wiring diagrams I can email you if that's any help?
Found this whilst messing about with wiring
Mounted my 'brain' box
It's got allot of stuff in it lol
Fuses,relays, ecu gauges, innovative stuff
The idea is if I ruin the car, or go back to a k10, just unbolt and bolt in new car without having to require the whole car
The cars a toy, so looks ain't a problem
Manual pedals in....
Drill this out
Bolt on pedals.........chore!!
Got my gbox mounts and shafts
The automatic cable speedo drive is too big for this manual box
Dam it
