Hi all
My first post.
Problem, changed the oil on my friends micra today but mistakenly drained the gearbox oil (common mistake I hear). I closed the plug after I noticed it was too clean so there is some oil in there but probably drained 1.5-2litres out. Micra is a Passion R Reg. 1.0 Litre.
Now Ive been looking at forums/guides and there is two options;
Speedo Hole Method
Before I go and mess things up, I was wondering if anyone has an actually photo of the speedo hole and the parts
I found the following on another thread;
-park on flat floor
-remove airbox to access the speedo gear
-unscrew the speedo cable from the speedo pinion unit
-remove 10mm bolt holding speedo unit onto gearbox
-rotate the speedo unit anticlock till you can grab the lip then pull up & turn
-stick a rod down the hole to measure the level
haynes says the RS5F41A 1.0L box should be 28-38mm high while others should be 45-54mm high. I just fill it till the speedo pinions fully submerged when inserted. bout 3-3.5L
My question is if someone can provide a diagram/phot of the following parts;
An actual pictures/series of pictures/diagrams showing where the filler hole is meant to be in relation to the drain plug. ( I cant find it!!!)
I would be grateful for any help tonight or tomorrow morning as my friend was intending to travel tomorrow night.
My first post.
- One is a filler hole (which I cant find)
- The other is through the speedo hole.
Speedo Hole Method
-park on flat floor
- Speedo Pinion unit
- Speedo cable connected to prinion unit
- The 10mm bolts connected to the gearbox
- speedo unit
