need help with my rev counter?
JJ 1.0l
now before people say go read the guides i have and i don't think they can help me.
basically i fitted a set of super s clocks into my 1.0 shape a while back. well mot time has come and i need it wired up. i ran the wire from the dizzy to the back of the clocks and nothing happened:( so i need to ask i few q's
1. which block do u connect it into i connected into the one on the left if u look at the clock as the driver posistion.
2.do i need to connect it to anything else?
3. do i actually need it to work for the mot?
cheers
Jordan
jordan
it wont fail an mot
of the 3 plugs behind the clocks, the one near the tacho is probably missing the blue/black wire on your loom, i presume you have to tap your wire into that empty contact ?
