Elabourate on the stuttering you mentioned. Was this bunny-hopping while letting the clutch out (as if the clutch was grabbing, letting go, grabbing, etc)? Possibility of clutch pressure plate failure anyone?
Other things which spring to mind of Yom:
Possibility of clutch fork failure (if the K10 design is anything like the K11, it isnt going to bend any time soon - its a very bulky cast piece of steel) and any problem here will most probably be the grub screws holding the fork to the shaft. This can be fixed with the gearbox off, some "lock-tight" and repositioning of the clutch fork.
Also visually inspect the clutch arm on top of the gearbox with someone else pressing the clutch. If it moves around 4cm, the cable is probably OK. If it doesnt move - check the cable (although you would be suffering pedal sagging issues if the cable was dying). The top clutch arm on the gearbox could also be bent/broken (quite common with uprated clutches/lack of lubrication on throwout bearing).
Other clutch cable related things to inspect would be the firewall mounting point for the clutch pedal assembly - could be cracked.
Sorry for the long post. I'm thinking today. Hehe.
