frank
ballast resistor andy ?It should idle but its shutting off as soon as I let off the starter button
I
I
It is indeed just thought it might help sorryThe mg is twin carb iirc...
Yup, twin hs4's iirc, except the yank single zenith models... yuk!The mg is twin carb iirc...
Don't be sorry silly! You may be right about it being fuel eh, we are all just firing ideas over, didn't mean to shoot your downIt is indeed just thought it might help sorry
I'm with you on fueling buddyIt is indeed just thought it might help sorry
Well its like I said I know nothing about carbs chap... and yh were all firing ideas on why she wont start.Don't be sorry silly! You may be right about it being fuel eh, we are all just firing ideas over, didn't mean to shoot your down
Cant be timing due to new dizzy and plugs are pretty straight forward...I'm with you on fueling buddy
On the coil? Never had one :/ worth sticking one onballast resistor andy ?
Custom wired ignitionwondering if k10 have the ignition switch fault like k11
Fresh in yesterdayCant be timing due to new dizzy and plugs are pretty straight forward...
Ive seen many bad reviews about the super 4s.
How old is the fuel itself andy?
If it never had one don't put one on. It'll probably have a built in one seeing as it was made after the 70's...On the coil? Never had one :/ worth sticking one on
the k10 had a ballast resistor built into the ign andy, so that the 9v coil was given a 12v feed during startup (then when you released the key it returned to 9v)On the coil? Never had one :/ worth sticking one on
If you had a side drought car this would be so easy to diagnose... I not seen the insides of a downdrought so can't help you there...This piston and vac pipe to the dash pots... where dya reckon I should be looking? Totally avoiding taking the carb off... but looking like I may have to :/
Even if it only fired on one cylinder :/the k10 had a ballast resistor built into the ign andy, so that the 9v coil was given a 12v feed during startup (then when you released the key it returned to 9v)
and if the resistor was shot or unconnected, the car would fire with the key turned but die when you let go
Haynes mentions no pistons... air bleed screws and jetd etcIf you had a side drought car this would be so easy to diagnose... I not seen the insides of a downdrought so can't help you there...
its a white crock stick/block on the bulkhead or flitch usually mateEven if it only fired on one cylinder :/
Hmm I used the original ignition wiring but on switches etc. When you say its built in... where abouts? Ignition barrel or nearer fuse box?
not if its only affecting 1 or 2 cyl, noCant see one... there was one on the K10 I stripped for the nissanubaru project
Not think its a fuel issue?
Perhaps some fuel evaporated off or some condensation evaporates off some electricsIT'S ALIVE
what did I do I hear you ask?
Ate my tea abd tried again and it struck straight up
So its just being a typical micrs then haha well done mateIT'S ALIVE
I'm guessing so. My celebration was prematurePerhaps some fuel evaporated off or some condensation evaporates off some electrics
Go have some more dinnerI'm guessing so. My celebration was premature
It died... and now refuses to start again
Try the old one?Think my new fuel pump is over powering it
That's my last resort. The oe pump is a guarantee to be right flow and pressureTry the old one?
Its a question of the regulator now and if it will reduce flow... not just pressure @enuo @skinner_87
Screw is in... can't get the dome nut on now... it might have a turn or 2 left.Instead of swopping over mate can you not just use that last inline regulator to bring the pressure right down? Done nut off the top & turn the screw right in?
I've a second regulator. A non return one.. worth sticking that in too?
Only the 2nd 3rd time I've had to use one... will screwing it all the way cut the fuel off completely? Never had one need to go in this far :/
Dont worry it'll get there.I've only just checked my little magic box of communications......
Could not believe it when I saw the title a little bit of me died inside....
I am no expert atall but fuel problem does sound logical from what everyone has said :/
Fingers crossed for you
Hopefully she'll be running b.e.a.u.tifully soon
X
I've a facet silver top fuelling the engine through the return regulator...I've only had mine in a few turns as well to be honest fella!
I need two reg's on mine mate, one with a return from the main pump from 30psi downwards to about 10psi, then another with a none return that bring its down to 2-3psi & it never floods at that pressure
First thing yesterday on first attempt with pumps and regulator mid open. Cyl1 plug was sopping. Though the other 3 were dry (cyl4 was firing)Are the plugs getting soaked after running with the pumps on?
They run 27 gal/hr @ 4-6psi apparently
The facet cube pump flows unregulated to the swirl pot. Still at 27gal/hr @ 4-5psi
If I wind it right in. To its lowest 1.5psi pressure... flow will still be 27gal/hr right?
As flow is what I need to reduce I believe.
Flow and pressure must be related :/
Ah well my pipe size has increased to 5/16... which I thought was standard size... its 1mm wider than standard.. so that wont help :/Id think flow is worked out by the pressure & hose size mate so they must be related! So id recon it would flow less than 27gal/hr anything under 4-5psi
Enuo will be able to tell use the right psi for these carbs
I remember reading that somewhere on here.we run a return pipe in our karts andy (to stop the carbs flooding) with a .7mm jet/restritor shoved inside it
