FS: K11 stuff
few bits
1.6 throttle body. £20
1.6 ecu £15
Cg13 ecu £5
1.3 throttle body £20
Blue painted rocker cover £5
Also have a 1.3 engine in millions of peices. everything there apart from sump and intake manifold.
Would prefer collection but if you want posting i will check prices for you.
If i find anything else i have lying around i will update the thread.
Did you notice a difference with the 1.6 throttle body and 1.6 ECU, can you see how much to post to wellingborough northants nn8 2pu for both items, if its not to much i have them.
Thanks Paul
Engine was in need of a rebuild, hence whys its in bits. piston rings and valve seals need replacing.
price. £10. would have to collect it all tho
