Dash not lighting up, Speedo, tach, fuel gauge, digital clock not working
First post so sorry if this is in the wrong section, issue as above on a 2004 K12. Everything is functional (lights, indicators, wipers, radio, heating, other internal lights) and the car runs, but the dash gives me pic related. After a while running, the immobilizer symbol comes on solid and stays on.
Pic is the dash while the engine is on, any advice?
2 options, one, it's not connected as indicator, 2 the little box of magic smoke has been opened and your clocks are fubar without the smoke. try the connector, if that doesn't fix it try a brakers for new clocks (obviously with the same mileage on ;) )
Yep, turned out to be the instrument fuses on the driver's side. I was scared to pull anything and make things worse, but compared the diagram on the fuse box cover with one found on Google and replaced the appropriate 10a mini fuses with new ones. Also rubbed the magic smoke box for its blessings as per @novocaine advice
All sorted now :)
