ok instead of going for the light weight flywheel because i cannot afford it, will i be able to use a normal ga16 flywheel to fit the ga16 uprated clutch to my 1.0l?
the ga f/w will bolt to any cg engine mart, but the pcd for the pressure plate bolts is bigger (for the bigger 190mm 1.6 friction plate)
and the 1.6 clutch has the bigger centre spline, like the bigger cg 1.3/late 1.0 g/box :grinning:
