D4R73N Ex. Club Member May 18, 2006 #1 As most know this is Titch's Kit, all i need is the details to do this myself, E.G Angles, Diameters of the elbows and pipes...
R runaway-robot Guest May 18, 2006 #2 thats two 45 degree bends... not 100% sure on diameter... best to go measure the filter, and the TB
OP OP D4R73N Ex. Club Member May 18, 2006 #3 runaway-robot said: thats two 45 degree bends... not 100% sure on diameter... best to go measure the filter, and the TB Click to expand... Are you sure, as the one on the trottle body appears to be heading downwards...
scottish-sr Ex. Club Member May 18, 2006 #7 wob_ert said: I'd have said the bend nearest the filter is more than 90.. Click to expand... Na, they are both 90degree bends, just sit the one on the TB at an angle to point it down more, basically have 1 side higher than the other. 2 of them and a bit of stainless pipe. Titch has to "make" a coolant relocation kit though.
Titch Micra K11ng May 18, 2006 #8 Coolent re-location kit came from the Evo as well. Was a ##### to get in as had alot of trouble keeping the presure into the radiator. PM me in future about it man as can get more details to you that way...
