too much oil
Yep, too much oil increases oil pressure, putting a strain on some of the engine internals. It's definately not recommended! If it's overfilled, drain the oil and refill to the correct level.
can also inrease pressure in the engine blowing out oil seals on some cars! especially crank seals, plus it can blow out of the breathers, as said drain some out and refil to the correct amount
if its slightly over full a mm or to on the dipstick you will be oc but much more than that you will want to sort it!
