Rumble/judder form the cluch.
M
mr.grassie
last night on my way home from work, i noticed that the car gave a little judder/vibration when pulling away from stationary when i lift the clutch pedal.
Does'nt do it when changing gears or on boost, only when you start moving from dead stop.
cluch isnt slipping, never had a problem with that.
have i killed my clutch? or could it be worse?
I think that it is most likely oil contamination also.
When i did my drive shaft i made sure there was plenty of oil in the gear box, so thats not an issue, engine mounts are fine (I check them reglarly).
I have done some head work recently, and i thint the seal between the dizzy and the head had gone (the half moon retaining cap held down with 2 bolts). there was a oil leak there, an that dirtectly above the clutch.
I fixed this last night, and it seems to be getting better.
fingers crossed.
mr.grassie can you get some pics and info of your car upon the forums?
ide love to know more about it and im sure everyone else would too
Meeting him on Sunday - will get all details then :)
