Rocker Cover Screw Removal...
Hello all,
I have tried everything I could thing f to do this, but still now luck!
I have used a hand screwdriver, ratchet set, drill, impact wrench and even heated the damn screws up, but they STILL wont budge. I have even worn one out now and I'm getting desperate now....
Any help pretty please?????
dremel a slot across the head and use impact driver
once removed, retap the thread holes to clean em, then upgrade those silly rusted philips screws to stainless socket bolts
I have used locking pliers with sharp heads. Also, if u can have some1 pushing rocker same time to down, it will help. I think ph3 is best bit head, i think it is philips, not sure.
