removing gearbox ?? help
whats the best way in removing a gearbox as if any1 has any insrtuction to removing it or pics
can help me so much thanks much a apprectiated :) ..
i'd suggest making this support bracket which will hang the geabox over its centre of grav so it stays level whenever you slot it in/out of the engine
http://micra.org.uk/threads/pollymobiles-rebuild.35251/page-49
post #2438
place a block of wood between the sump & central beam to stop the engine dropping down,
driveshafts, selector rod & plugs disconnected,
crane up the gearbox with the bracket slightly till the crane just about supports the gearbox weight,
unbolt the rear mount, gearbox mount,
lower the engine & box till it just rests on the wooden block,
unbolt gearbox from engine,
slide/shake gearbox away from engine,
lower onto floor[/LEFT]
ya i was just talking about this with me pals but im just wonderin reali is there anyway in acc taking it apart as too what to dissconnect 1 my 1 ..
very good idea on bracket and i watched your vids on your page off testing car out sounds awesome on 5:10 i think :)
To be honest mate the best way is to just tackle it your self.
Take you time, look at what you have to remove to get it out and take your time. As pollyp said there are only really a few steps to removing the box.
I learnt all i know by just going for it. I can now do engine changes on the drive way.
Where are you? Im sure someone will lend a hand if you are local.
