Magpie42 Actual Magpie. Feb 8, 2014 #1 Changing Mike Micra's springs but cant work out how to get the front brakeline clip off...hmmm... Any help would be muchos appreciated! Sent from my RM-892_eu_euro1_205 using Tapatalk
M Madmonkee Feb 8, 2014 #3 Big pair of grips I used mate, get hold of it from both sides as you look at it, wiggle left and right as pulling, done
OP OP Magpie42 Actual Magpie. Feb 8, 2014 #4 By hitting it at the back ridge or under the prongs? Sent from my RM-892_eu_euro1_205 using Tapatalk
frank Club Member Feb 8, 2014 #5 Magpie42 said: By hitting it at the back ridge or under the prongs? Sent from my RM-892_eu_euro1_205 using Tapatalk Click to expand... the ridge
OP OP Magpie42 Actual Magpie. Feb 8, 2014 #6 Ok...thanks fellas, I give both a try....! Sent from my RM-892_eu_euro1_205 using Tapatalk
M Madmonkee Feb 8, 2014 #7 They similar to this, either the clip is on the front of the shocker bracket or the rear, cant remember, grab wiggle and pull, the clip locates into the hose as per pic
M Madmonkee Feb 8, 2014 #9 Gives you an idea of where it slides into on the brakeline Sent from my GT-I9505 using Tapatalk
OP OP Magpie42 Actual Magpie. Feb 8, 2014 #10 The hammer and screwdriver worked a treat! Now...got the shock out and the compressors on, how the hell do you get the top nut off? A vice? Sent from my RM-892_eu_euro1_205 using Tapatalk
M Madmonkee Feb 8, 2014 #12 Swan neck spanner and allen key? Or soft jaw grips on the piston rod and socket?
OP OP Magpie42 Actual Magpie. Feb 8, 2014 #13 Worked it out...loosen when its still on the car...! Sent from my RM-892_eu_euro1_205 using Tapatalk
OP OP Magpie42 Actual Magpie. Feb 8, 2014 #14 Those brake clips come out easier than they go back in! Sent from my RM-892_eu_euro1_205 using Tapatalk
