rear roll bar removal? car to stiff?
squarepants
as above...just wondering here, i have heard of people in compition removing the rear roll bar as the rear end is too stiff...
so if the back wheel comes off the floor on hard cornering does this mean the rear end is to stiff? therefore would removal of te rear bar anti roll bar keep the wheel on the floor under cornering?
bear in mind also using stiffer spprings and uprated shocks?
dan
Stiffness of the rear end can cause this, i run a standard anti-rollbar on my rally micra, with bilstein coilovers and nismo bushes, there is no body roll as it is stiff but the wheel does tend to lift if conering too hard. Could be body roll in some cases, however, it tends to lean and travel rather than lifting a wheel.
Alex
