Rear disk conversion!
Do i have to fit a rear axle that originaly had disks or can i modify one that came with drums? I realise cables and pipes have to be changed!
If you are after some brackets to convert your normal rear axle give me a ring 01865 748000 just ask for Matthew, I might even have some callipers
Golf rear calipers are a good fit if you want to make some custom brackets :)
goldstar0011 said:
I think any calipers would work as long as the discs that are used are 4x100 PCD, choose something with cheap discs and pads :D
almost... they also need a cable for the handbrake so you can only use rear ones...
goldstar0011 said:
Well, ye, is all that too, but if anyone is attampting am sure they will have some idea of what to do, i hope!
yea you'd hope so eh :D
someone do a guide ;)
