H
Herr_spl1ff
Hi, looking at a '95 2litre primera diesel, non turbo, does anyone know what they're like and what sort of fuel consumption they get? Or anywhere can find out (apart from the NPOC... )
NeX said:yea agreed, the fuel consuption will be amazing
Yom said:Not on the older models. Even a modern turbo diesel will chew just as much fuel as a similarly sized petrol if driven hard.
MA12:) said:yes Nex but diesels have that low down lazy torque, straight up to top gear and no need to change gear again till your destination.
Herr_spl1ff said:Thanks for all the resonses, impressive in a short time! So general agreement is the non turbo is ok for consumption but pants for performance? Sounds ok, would get a TD if I could afford but sadly too skint at the mo.
Fordy said:and they are cam belt so more expensive when you come to service it every 54k or 5 years
Most small nissan diesels in passenger cars seem to be belts. I think thats because they sourced the european diesels from the european manufacturers. Domestic Japanese models don't have a diesel engine at all unless its a truck or utility vehicle (and I don't know any nissan diesel from japan which has a timing belt - but there are a few petrols from the early 90's which use a belt instead of a chain. CA, RB (except RB30 varients) and VG come to mind.NeX said:ooh are they? i thought nissan stayed away from belts and only did chains...
that is very useful to know
