P purp k11 Mar 16, 2012 #1 Hi all does ga16 mount up to 1.0 g/box , shafts etc as only cg13 to ga16 covered ,guessing cg13 parts more robust / suited for ga16 conversion?
NeX You're after my robot bee Club Member Mar 16, 2012 #2 1.0 and 1.3 box are about the same, you are not going to strip the gears with a stock 1.6 engine
frank Club Member Mar 16, 2012 #3 it would bolt to a pre-facelift 1.0 if you also used the f/w and clutch, and opened the f/w centrebore up
