Wavey87 Jan 25, 2012 #1 My rad fan is stuck on (ive dosconnected the battery to stop it draining) would I be right in thinling this could be the relay? Thanks in advance
pollyp Club Member Jan 25, 2012 #2 check the 2-pin coolant sensor is reading within spec and not shorting out (very low Ohm tells ecu its hot so it engages fan relay), then check the fan relay isn't stuck on
