Matiz fronts problem
Ok i finally have matiz fronts and corsa c rear shocks but i was wondering how you loosen the top nut on the matiz shaft to change the top mount? Any easy way without impacto wrench??
the matiz shaft is bigger, with a flat edge machined down the side, so you can usually get some oil into the thread and jar it loose with a ring spanner :)
