pork Club Member Jul 26, 2011 #1 Which one do I have? Iv read bits n bobs about higher compression heads than others Iv got a micra L 1.0l 4 speed. My bike carbs are almost ready to go on so I'm already looking at what else I can do. So what can I do to the head and at what cost?
bobsp16 Site Supporter Jul 26, 2011 #3 it dosn't matter which one youve got there both the same if you want more power fit a skimmed 1.2 head for better flow
A aLLeKs Club Member (Trial) Jul 26, 2011 #4 polish the ports, skim the head, get a more aggressive camshaft.
frank Club Member Jul 27, 2011 #6 pork said: How much can I skim? Click to expand... the 4 speed 1.0 is only 9.5:1 pork, so 2mm with a better cam maybe ?
OP OP pork Club Member Jul 27, 2011 #7 frank said: the 4 speed 1.0 is only 9.5:1 pork, so 2mm with a better cam maybe ? Click to expand... Cheers, could you recomend which companies to use? New to all this so have no idea who to ask. I'm in Luton if that helps.
A aLLeKs Club Member (Trial) Jul 27, 2011 #8 Is 2mm possible without knocking. I have a 5 speed ma10 and I always skimmed my head 0,5mm. I have a spare head which is going to be skimmed. So if I skim the head 2mm which compression ratio would I get?
frank Club Member Jul 27, 2011 #9 aLLeKs said: So if I skim the head 2mm which compression ratio would I get? Click to expand... you would have to work it out alleks http://www.race-cars.net/calculators/compression_calculator.html my previous cga engine was 9.5:1 before the 2mm headskim
A aLLeKs Club Member (Trial) Jul 28, 2011 #10 thanks, but if I type in the standard values I get something like 1.9xxxx:1
frank Club Member Jul 28, 2011 #11 aLLeKs said: thanks, but if I type in the standard values I get something like 1.9xxxx:1 Click to expand... try for the 4 speed 9.5:1 (with a supposed small 2.5cc dish in the piston) 68 68 4 22 -2.5 1.2 and for the 5 speed 10.3:1 68 68 4 22 0 1.2
