lowering decisions!
ok so,
im stuck in a rut between, matiz and corsa setup or spend loads of money on lowering springs?
anyone know the pro's and cons of both?
im currently running... 're-engineered' standard micra springs ;) , and im just not happy with it!
also.. any other cheap little mod idea's you guys wana share would be much appreciated!
I guess Matiz is cheaper and can lower between 50-80mm with dropping the perch?
Corsa is height adjutsable but the ride tends to be much harder.
You'll pay through the nose for a set of measly springs which you'll end up chopping like everyone else.
Use matiz strut and spring for the front and corsa b shocks and cut standards on the back :) there is other methods like using alto springs or wagon r springs but I just used that :)
What springs do i use on the matiz setup if i bought the front shocks ?
matiz front springs are tapered a bit, so the choices are limited, dropping the perch will give an 80+mm drop (lower one in pic)
Frank did you reweld the spring perch on the matiz shock or are they ok to run without welding?
ran for about 1 month, then welded a collar under them to lift them up a bit karl :) (different size collars to level the car)
