sounds like an internal gear selector issue if the 5 forward gears are ok, does the stick go into full reverse position ?Hi can anyone help I have a slight problem with my k11 1994 micra, that I have lost my reverse gear I have tried to adjust gear linkage but still no luck all other gears are fine.
I thought that replace cable yesterday but still the same.cable stretch?
No the stick does not go in to reverse at all.sounds like an internal gear selector issue if the 5 forward gears are ok, does the stick go into full reverse position ?
the stick will jam if the rear g/box mount is loose, but you tend to lose some forward gears too when that happensNo the stick does not go in to reverse at all.
tbh you need to run that test in reverse gear iirc (which you dont have )Ok thanks I will try that.
Check the rods not rusted like my 94 lx. And bushes for shifters and sectors are free for it to go in that direction,Ok thanks I will try that.
