hi guys, I have k10 with MA12S(1.3L) engine and i will replace it with CGA3DE(1.4L) and i want to know what modification i have to do to install this engine
i need help here guys i'm new to this and this is my first project,thanks guys
my CGA3DE engine
What is it that you would like to know?
You need to let us know of how you expect to do it so that people can help you with the things you are finding difficult with your plans.
If you are expecting to just bolt it in with mounts supplied to you then you are in for a shock, you have a big job on your hands, but it has been done before
i did mine different to the link above, i kept the k10 gearbox shafts and front, back and side engine mount and the only think i had to fabricate was a drivers side engine mount, no body mods were done what so ever
I've been considering this myself
But I have a problem that reoccurs
I think right I'll fit a cg13, then I think if I'm going to the trouble of that I mayaswell fit a ga16 then I think well if I'm going to do that may as well fit an sr20
Then I check the bank and see I can't do any of it
I may just do that, that way I can add it to the list of services I can offer when I get my new garage! Doubt I'll turbo it not worth the hassle I'll probably drop an sr16ve head on an sr20de(t)(none turbo sr with a turbo strapped on) low boost massive power:blues: drop it in the k10 at a later date
