JDM Exhaust Fitment Problems - HELP!
Hey guys,
I imported a used Japanese exhaust system for my k11.
It consists of the downpipe, mid section and back box.
For a bit of back ground I have a 1.0 Coilpack engine.
When I went to fit the exhaust, the downpipe hits the floorpan, I bolted the mid section onto it, but the mid section slants downwards and hangs low where the right angle bend is, just before it bolts to the back box. If i try to lift the mid section to sit parallel to the floor pan, as it should, I cant as the downpipe hitting the floor pan prevents me from doing so.
I have looked at many japanese manufactured aftermarket downpipes and they all have the same shape as mine.
Any ideas as to why this may be?
I have heard that coilpack model k11s like mine, have a longer cat and exhaust manifold, so could it be the downpipe i got with my exhaust is from a dizzy model which has a shorter manifold and cat?
I find it hard to believe it would cause such a clearance issue.
Any help appreciated.
You do need the correct downpipe depending on whether it's coilpack or not. Otherwise you need to swap the cat to the earlier one.
Sent from my Nexus 5X using Tapatalk
