antony_aiken said:
"ITS ALL ABOUT THE MONEY, ITS ALL ABOUT THE DUM DUM DADADA DUM"
seriously, i could recomend the Jonah Lomu series subs and amps from fusion...
the amps come in several sizes.... the smallest being a 2000WRMS single channel from 1ohm stable, 2ohm and 4ohm application. although its about 4ft long and wont fit in a micra boot.....(ive tried)
my install.....
JVC KDG-9102 pict head unit....
audiobahn 12" sub running from an Alpine MRD300 V12 amp,
also custom leather install from a Vibe CBR Active 10" evolution amp package on the opposite side of the boot,
infinity Kappa 360W 6x9's in the rear footwells powered by a Vibe BB1 400W amp,
Front speakers are Vibe SEK 6" Kevlar components from another BB1 400W amp.........
it is soooo freekin loud.....i mean almost blow your head off loud...and no distortion...
im sure it has allready been said.... but you dont have to stick with one company either.... in fact that can be a very bad thing to do.... read up some reviews and see what performs the best....
thats what i did...
Vibe Infinity Alpine Audiobahn JVC...........the best of the best as i could afford..
A 12" and 10" of different makes in the same airspace?! :suspect:
I wouldnt say Vibe or Audiobahn are that good really, all show and no trousers.
I'd say, for a decent setup Batch, try this:
Subwoofers:
2 x JBL 12" GTO 120D's - fantastic subwoofer for the money, awesome sound, and great build quality. Also matched well to quite a few amps:
http://www.caraudiodirect.co.uk/product_info.php?products_id=4235
Enclosure:
CAD Twin 12" subwoofer enclosure - a decent enclosure for both subwoofers if you dont want to build your own:
http://www.caraudiodirect.co.uk/product_info.php?products_id=4279
Amps:
1 x JBL GTO 601.1 Mono Channel Subwoofer Amplifier - Wire this mono channel amp in parallel with the two subwoofers to give ~600wrms (300wrms per sub) to the subwoofers:
http://www.caraudiodirect.co.uk/product_info.php?products_id=4134
1 x JBL GTO 75.4 4-Channel Amplifier - Fantastic for the price, at least 100wrms per channel, great for powering 2 sets of components, are giving loads of juice to one set of components (bridge 2 channels):
http://www.caraudiodirect.co.uk/product_info.php?products_id=4140
Wiring:
1 x CAD 4awg wiring kit - plenty for what you need!
http://www.caraudiodirect.co.uk/product_info.php?products_id=204
1 x CAD distribution block (for amp grounds):
http://www.caraudiodirect.co.uk/product_info.php?products_id=4754
1 x CAD fused distribution block (for amp power):
http://www.caraudiodirect.co.uk/product_info.php?products_id=4752
1 x QED pack of fuses (pair of fuses for distribution block, come with blue LED's):
http://www.caraudiodirect.co.uk/product_info.php?products_id=3443
1m (or whatever you need) CAD 8awg power wiring (red) - for fused distribution block to multi-channel JBL amp:
http://www.caraudiodirect.co.uk/product_info.php?products_id=3271
1m (or whatever you need) CAD 8awg power wiring (black) - for amp to distribution grounding block:
http://www.caraudiodirect.co.uk/product_info.php?products_id=3270
1m (or whatever you need) CAD 4awg power wiring (red) - for fused distribution block to subwoofer amp:
http://www.caraudiodirect.co.uk/product_info.php?products_id=3269
1m (or whatever you need) CAD 4awg power wiring (black) - for subwoofer amp to grounding distribution block:
http://www.caraudiodirect.co.uk/product_info.php?products_id=3268
10-12m ish of QX Connect speaker wire - For the 2 sets of component speakers, get as much as you need, but it should be suitable for taking all the power right to the components:
http://www.caraudiodirect.co.uk/product_info.php?products_id=3411
Component Speakers:
Now this really depends on the size you want, but ideally, the bigger the better. With the above 4-channel amp you've got loads of power on tap, so why not use it!
You also really do NOT need extra tweeters in the B-pillars. If you've got externally amped speakers and they are set up correctly, you just wont need them. My single set can easily take my head off if needed!
I'd personally suggest 2 sets of these Alpine Type-S's - they should lap up 100wrms each!:
http://www.caraudiodirect.co.uk/product_info.php?products_id=3337
If you want to save a bit of money, then get 2 sets of the following:
http://www.caraudiodirect.co.uk/product_info.php?products_id=5135
Finished!
That lot will set you back just over £600, but includes the Alpine components, or under £600 if you go for the cheaper JBL's.
Imo that would be an awesome setup. Lots of power on tap, 2 subwoofers, seperate amp for the components and 2 sets of nicely powered components, along with all the wiring!
Let me know what you think
Pete
