how to tensioning drivebelt
Hi,
I recently changed my drivebelts and wonder if i adjust correctly the tension.
if I understand, the tension should be checked or is the red arrows?
Uploaded with ImageShack.us
I check the tension or is the blue arrows because it is easier to access, are good?
tx
So, down it doesn't good? but is the longest exposed side of the belt between pulleys.
Can you show me on the picture?
Tx.
dont worry too much about the waterpump belt niko, here,s how slack mine is
but the alternator belt needs to be pretty tight tho
which one is ur setup? ...
actually I'll just mark on the sheet where to check. be sure to turn the engine 1rev after adjust the tensioner to even the tension and then recheck the deflection.
