i pull the g/box off and down on my preface 1.0 leon (shafts, starter and gearchange still fitted) but ashley,s facelift 1.0 g/box would,nt lower down for some reason, so we pulled the g/box to the right and changed the clutch in the 6" gap (twas surprisingly easy !)please help cltch has gone and i need my car for tomorro and dont finish work till half 4so starting then, so help would be grate pleaseeeeee help
half hour on mineso i'll take about 3hrs then?
my shafts have never been out (damn messy job !), but if yours is a pre-face 1.3 it will have the same (bigger) g/box as ashley,s facelift 1.0, in which case you may not be able to lower it down ?okays thank you do i need to remove the drive shafts form the hubs or gearbox at all?
the thumb nut under the battery mate (with a 10mm locknut) and is the clutch 160mm ?ive already got my clutch it in the boot of the car but if you think adjusting it first would be best could you please tell me how to do that? im useless with micras haha
