Helloweens`s K11 Micra _-_-_-_-_-_-_-_-_-_-_-_-_-_-
Good job ! I advise you to get a harness from Phil (PJG1979) pro quality. You can ask me or check my thread if you need informations on the wiring. Keep it up !A
Thanks for your kind comments guys, with the harness, i used to be a car electrician for BMW Motors so i wont have a problem there but thanks!!!! also what benefits would it be if i removed the front panel cover in front of the manifold?
J
Will930, i dont have a heat shield on the exhaust, i have a 4 branch fannimold!! is it the shield plate in front that i painted/hammerited is what you mean will930?
J
You've done lodza work on it, J!
Good, good, I like it (Y)(Y)(Y)
Cheers peposhi!!!
no benefits as such, a little less weight and a bit more air coming into the engine bay
Cheers emmet_gti, ill whip it off tommorrow, also need to get a new front number plate made up aswell, dont wanna screw it down.. rather double side tape it down etc....
Cheers...
J
