handling - tracking
Robert
I've been having problems with the handling of my car lately, and hoping for a bit of a diagnosis from you guys.
-I've somehow lost the back end around a corner, doing 60, but it was wet. I've taken the same corner at 80 before and had no sign of a problem, even a twitch, but that was dry.
-I've encountered bad understeering several times.
-Car seems to want to go in the direction it wants, usually pulling to the left.
Tyre pressures are ok, (32psi front, 30 back) and had a garage check them too. Just had my tracking done.. here's the big bit.
It was about a half inch out, would that give me these symptoms?
I'm waiting for the road to be dry to give the car a proper run so i can tell if it's better or not.
robert
1/2 inch out is pretty bad !, was,nt it scrubbing the tyres ?
i find a k11 with decent tyres on the front will understeer if you,ve got any power on, and oversteer if you lift
