Hi all,
I'm just wondering if anybody can offer me some help or advice.
Ive got a 1995 1lt K11 and currently its running Adjustable Koni's on front and rear, Whiteline Panrod Arm kit and an OMP strut brace. The car itself handles very well but its still a bit "rolly" and it doesn't always inspire as much confidence as I think it should with how it rolls.
The car is used for Grass Auto tests and gets a lot of use down the lanes (country bumpkin that I am) so lowering it isn't really an option as Id have no sump left, what are my options in your opinions?
Ive just got the standard 13" Steel wheels with some Toyo tyres (just run of the mill shopper ones) on it and while they seem to stick quite well, I was wondering how wider tyre can I go for on a standard steel and if anyone has any suggestions as I think a lot of the roll is on the tyre wall looking at photos of the car when its been cornering.
The other option would be anti-roll bars but I have neither the knowledge or the funds to fabricate brackets for the rear or change the Axle, which I believe is the only way to fit them onto a pre-face-lift model? If that is the case, is it possible to just a fit a front one or would this not help or worse, upset the balance of the car if only the front was done.
Many thanks for reading and I look forward to your advice!
Chris
Chris
