Actually, if you put the pump in the fuel line, you can use almost any inline-fuelpump if they produce enough pressure and fuel flow to your system. Electrical fuel pumps from carburated cars won't work because they don't produce enough pressure.crogthomas said:You would need to arrange a high pressure fuel pump for the injectors as well...
I wonder what the Micra ST uses? Perhaps another model in the Nissan range could donate its fuel pump?
bobsp16 said:in autograss racing the class 4 k11's some run R1 bike carbs and others throttle bodies but they are pushing out there 1130cc cg10s to around 140bhp,but the only part left inside the engine that you could call nissans is only the crank.and i would say to get the cc up to a longer stroke thats heaverly ground to an offset
Speedle said:bloody hell! that some serious power, is that at the fly or the wheels bob?
Speedle said:how much would these guys charge to get an ma10/12 up to a decent spec? do they make manifolds and the such too?
Mark said:sounds good bob,
how long do the engines normally last?
Speedle said:so 100 bhp ma10 is a pretty easy thing to achieve then.
you got there contect details please bob?
